Hi all,
I have a video that is quite dear to me but unfortunately dreadful quality. It's in WMV format and I've already converted it to MP4 and AVI - MP4 coming out the best and better quality than the original file. However, I wondered if there was a better conversion or any other idea which might increase the quality of this video - if anyone has any ideas I'd be very grateful?
Thanks in advance.
Nick
Usually it only gets worse, because of lossy compression. Each time you convert it with lossy compression, data is thrown away
It depends what you mean by "dreadful quality". If there is something specific, then you might be able to apply a specific filter to improve subjective quality (e.g. if too bright, then darken, if too noisy, then denoise, if it's too blocky, deblock it...etc.. you get the idea) -
By dreadful quality I mean that it's barely watchable. The picture is all broken up and you can't really make out what is happening at times - I've gone to properties of the actual file and note that it says '15 frames per second' where as all my other videos seem to say 30 frames for second........possibly this is the reason.
There is a definate improvement when I convert it to AVI and a bigger improvement after being converted to MP4. It's still awful though and hence I wondered if there was a better format or something else I'm not thinking of?!
Thanks, Nick -
No not at all - thats not what I said is it? I said that there has been an improvement and I wonder if there is another format which would be even better than MP4. Rather than waste my time being rude - maybe you should either try to be helpful or crack on with some work and not spend your day making sarcastic remarks.
If VHS was wider, would quality increase?
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2010, 06:25 -
Increase the bitrate---> Lose Quality?
By mark63534 in forum Newbie / General discussionsReplies: 10Last Post: 21st Jul 2010, 14:36 -
MeGUI conversion for xbox 360 on 20 min TV show, quality is bad x264.
By xsirxx in forum DVD RippingReplies: 6Last Post: 30th Apr 2009, 13:52 -
Will the quality increase if the bitrate is higher after conversion?
By Choppa in forum Authoring (VCD/SVCD)Replies: 16Last Post: 3rd Jul 2007, 10:23 -
ffmpegx.... 3GP conversion= bad quality
By PIZZ in forum ffmpegX general discussionReplies: 1Last Post: 7th May 2007, 12:04
