hello everyone
i'm trying to make a DVD that will play on a set-top DVD player. the source is an .AVI of an out-of-print 1930s black/white movie. (this is the only source i've been able to find anywhere)
i usually just use VisualHub, but when i tried to play the VIDEO_TS file from the resulting .ISO the audio was all choppy before it crashed VLC (used to test before burning)
so now i'm trying 'ffmpegX 0.0.9y' (my first experience using)...
these are the settings i've used so far. (the resulting VIDEO_TS file does play on VLC. the video looks fine but the Audio sounds like chipmunks)
from the ffmpegX 0.0.9y 'Info' button:
VIDEO: [XVID] 592x432 12bpp 23.976 fps 1736.0 kbps (211.9 kbyte/s)
audiocodec: framecopy (format=2000 chans=1 rate=48000 bits=16 B/s=24000 sample-1)
from the 'Source format' panel:
Video: mpeg4, yuv420p, 592x432
Audio: ac3, 48000 Hz, mono, 192 kb/s
from the 'Target format' panel:
To: DVD mpeg2enc (Preset)
from the 'Audio' tab:
Audio Codec: .MP2 (was the Preset default but maybe should be ac3 to match source?)
Audio parameters:
Audio bitrate: 192
Sampling: 48000 Hz
Channels: mono
Mode: CBR
Audio track: 0
admittedly i don't know what i'm really doing but i don't know what other options to look at.
any help would be appreciated. it's a fun movie i'd like to enjoy on my tv.
- Your source file has AC3 audio.
- DVD supports AC3 audio.
Try setting the Audio codec to "Passthrough". With this setting the other audio settings are ignored and the audio stream will be copied as-is to the output.
Also check the "Set 3:2" checkbox in the Options tab to mark the output video with a 3:2 pulldown, as should be set for 23.976 fps DVD video. This should prevent choppy playback.
How to choose audio track in avi file with two audio tracks
By newnews in forum AudioReplies: 3Last Post: 26th Oct 2010, 05:26 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
How to use only one audio track from a 2-audio-rack .avi File
By akulier in forum ffmpegX general discussionReplies: 2Last Post: 21st Feb 2008, 03:28 -
how do i choose the right audio track going from avi to dvd output?
By kenzo69 in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2007, 19:36
