What is the easier way burn a movie file to a dvd.
I have some movies in x264 / 448kbps 640kbps with AC-3 audio.
I also have XviD movies with the same audio.
What do I have to do to make these playable by putting them on a single DVD.
EASIEST way - Buy a media player like a Western Digital or similar model and play your files as they are with NO CONVERSION. Get on with your life.
Otherwise use something like ConvertXtoDVD.
Exactly how many movies do you propose to put a "single DVD"? You should be aware that to make true DVDs you are going to have to do lossy re-encoding and the more movies you try to stuff on a single DVD, the worse the quality will be. I wouldn't recommend putting more than one film per DVD.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
HDTV makes DVD movie look "less" like a movie?
By breakchange in forum DVB / IPTVReplies: 73Last Post: 6th Oct 2011, 10:28 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 21st May 2011, 00:16 -
How can I convert a widescreen movie to full screen movie on PSP?
By VidHunter in forum MacReplies: 2Last Post: 9th Nov 2008, 23:20 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
