Hi all
I’m using
DVDx 1.7
Have a AMD 900 Mhz
DVD/CDROM player
CDR/RW
WinDVD
WMP v.7
I burn my VCD and when watching them I get nasty pic jumps. I try both PC :cry: drives and still the same. I use home made disks in my Work PC that’s less powerful than mine and can watch the movie like on my DVD player.
What is wrong.
By pic jumps I mean the image stops and then catches up jumping from one scene to another without passing trough the one in between.
Any clues about this?
Thanks in advance
Carlos
at last and since no1 could help me I tried and tried and finally I got it. It was my weak PSU that caused this problem. I had other problems which could not be explaind and finally I have rest from these anknown nightmares.
Keep this in mind if you have a problem that look like you can-t solve it because it doesn-t make any sence.... consider the PSU. At least check how much is its output. Imagine mine was a 150 watts unit. Can you believe it!!!!!?????? I bought the PC 1 and a half yrs from Tiny (*rse holes) and since then I had to buy a new HDD and this PSU.
cheers
EE
MPG jumps ahead
By Stokesy in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 1st Jan 2014, 09:54 -
BD-R jumps through chapters
By dingo2000 in forum Blu-ray RippingReplies: 15Last Post: 16th Sep 2011, 12:58 -
MPG still Jumps Ahead
By Stokesy in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 31st Mar 2010, 14:13 -
sudden brightness jumps
By carmatic in forum RestorationReplies: 14Last Post: 24th Jan 2009, 11:05 -
Dvd jumps when played
By Radox The Green in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 13:56
