    Oct 2009
    Singapore
    Hi., pls share your knowledge abt this.
    Is it possible to resize a video file (width x height) to a figure larger than the source input?
    Ex: I have 768x432, I want to re-encode and resize to 1280x720
    I have been using MeGui, and it doesn't seem like able to do that job.
    Yes, it's possible to upscale but you wont get any real HD.
    I don't use megui but I think you can adjust the avisynth script and you might also want to add some upscaling filters. Google avisynth upscaling.
  3. Yes, you can resize with megui, if you open avs script creator. It will use lanzcosresize of avisynth which you can change.
    Oct 2009
    Singapore
    Now I notice upon opening avs script creator, in filter tab, the resize filter choice is ,by default, Lanczos (sharp).
    However, it doesnt allow me to upscale. Is there any additional script/filter I might need?
    thank for your reply.
  5. how does it "does not allow you to rescale"? just put your desired size on the corresponding box, it could not be easier.
    Oct 2009
    Singapore
    it set the max number to the my input size.
  7. Hmm seems like a bug, or maybe it's by design, I never bothered to upscale so I didn't know that, sorry.
    However, if you edit it on the script tab, it works fine. e.g. changing LanczosResize(768,432) to LanczosResize(1280,720)
    Oct 2011
    Burbank, CA
    it set the max number to the my input size. [/QUOTE]
    That may be because you are targeting a specific profile/level. I believe that main/3.1 (for example) has a maximum resolution of 720x576.
    ...or not. Just a guess.
    Bill Caulfield
    metroencoding.com
