Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I finished paying with a credit card in Taiwan, also made Serial number, but VOB2MPG PRO installed and turned on, after about 10 seconds, the registration screen will automatically turn off, even if I use the fastest speed Serial number and Registered email entered into the registration screen, finish the registration page operation, VOB2MPG PRO, or not start, open VOB2MPG PRO, still to be re-certified, certified repeated action, but still can not use VOB2MPG PRO, please give me a refund
    Feb 2012
    U.S.A
    you should check the language in the advanced tab unicode setting language has to be English, if other language is used . it will turn off after several seconds.
