Hello everyone,
This is my first post! Unfortunately I am stuck ):
I have a couple hundred .mp4 files, converted using handbrake from DVDs, and they are all 6 channel AAC audio. My HT receiver cannot decode AAC but it can decode AC3, unfortunately I did not know this until now. I was hoping that a batch convert option was available somewhere, I don't want to change the video track, just the audio.
I know I could demux the streams, convert the AAC to AC3, then remux back. But for a couple hundred files that would get old very fast.
Anybody have any ideas?
Results 1 to 12 of 12
http://www.any-video-converter.com/products/for_video_free/
This will allow you to load all your files and then batch convert.
Experiment with 1-3 clips first to get the parameters correct. -
I know of that program and have used it before, but can I convert only the audio track using that program and just leave the video untouched?
You could try xmedia recode, open all mp4s, under format choose mp4, under audio choose ac3, under the video tab choose copy. But you wont get 5.1 ac3.
If you want to convert to ac3 with 5.1 I think you have to use eac3to. I don't know any guis that batch convert. -
The insane but cheap solution as long as your time means nothing to you-
Use anything to convert those hundreds of files to AC3 audio.
The sane but non-free solution-
Just buy a Western Digital or similar media player and play the files as is. The WD supports AAC audio. -
Unfortunately, I don't see a way to do what you wanna do.
You could do it in three batches with MeGUI, though. You can queue up multiple files to demux, click "Start" and walk away for awhile (3-4 minutes per?). When they've all been demuxed, set up the conversions. You can set up one AC3 profile and just load all of the .aac files with that profile and queue 'em up. Click "Start" and walk away. Upon completion of that, Remux using the same formula.
Sucks, but I don't know of anything that will do it otherwise. -
AVC is, among many other things, a sort of GUI for Mencoder.
A look at the AVC vdoconv.log gives some parameters.
Install MPlayer.
Save the following line as a .cmd file (e.g. test.cmd) changing the path to mencoder.exe to reflect its location on your computer.
Run test.cmd from the same folder as one of the MP4 clips.Code:for %%a in ("*.mp4") do c:\Path To\mencoder.exe -mc 0 -ffourcc DIVX -ovc copy -channels 6 -oac lavc -lavcopts acodec=ac3:abitrate=384 -o "%%~na_NEW.mp4" "%%a"
May we have the 'Mediainfo' results from one of your clips. -
When I do what you suggested pcspeak the command module window opens and closes very quickly. Too quickly for me to see what is written. I did change the path to mencoder.exe. Any ideas? And where should I expect the output file?
General
Complete name : E:\My Documents\My TV\The Office\Season 2\E01 The Dundies.m4v
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 458 MiB
Duration : 20mn 53s
Overall bit rate : 3 062 Kbps
Encoded date : UTC 2011-09-23 10:15:07
Tagged date : UTC 2011-09-23 10:19:36
Writing application : HandBrake 0.9.5 2011010300
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 20mn 53s
Bit rate mode : Variable
Bit rate : 2 608 Kbps
Maximum bit rate : 3 901 Mbps
Width : 720 pixels
Height : 478 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 23.976 fps
Minimum frame rate : 15.986 fps
Maximum frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.316
Stream size : 390 MiB (85%)
Writing library : Lavc52.94.3
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 20mn 53s
Bit rate : 442 Kbps
Maximum bit rate : 722 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 66.1 MiB (14%)
Language : English
Text #1
Format : mp4s
Codec ID : E0
Duration : 20mn 4s
Bit rate : 8 147 bps
Maximum bit rate : 4 290 Mbps
Stream size : 1.17 MiB (0%)
Language : English
Tagged date : UTC 2011-09-23 10:19:25
Text #2
Format : Apple text
Codec ID : text
Duration : 20mn 53s
Bit rate mode : Constant
Bit rate : 1 bps
Stream size : 92.0 Bytes (0%)
Tagged date : UTC 2011-09-23 10:19:36 -
Aha! Not MP4 but M4V with a bitrate of 442
Changed the bitrate and added a pause.
I don't think it will work, yet.Code:for %%a in ("*.m4v") do c:\Path To\mencoder.exe -mc 0 -ffourcc DIVX -ovc copy -channels 6 -oac lavc -lavcopts acodec=ac3:abitrate=442 -o "%%~na_NEW.m4v" "%%a" pause
Is it possible to upload a small sample clip?
I can't seem to find an m4v with 6 channel AAC. Plenty of 2 channel.
Cheers! -
It did not work unfortunately, but I am very thankful for all the work you are doing! Here is a screenshot of the command window, which now stays open but still doesn't work. http://imageshack.us/photo/my-images/11/unledwtv.jpg/
I can upload a small sample clip, but not right now. Later today I should be able to. -
Because of the spaces in the path string you must have double quotation marks around it.
"c:\Program Files (x86)\AnvSoft\Any Video Converter\gnu\avc\mencoder.exe" -mc 0 .................
Edited because I missed the last post:-
I agree. Using handbrake, which I have never used, is probably the way to go.
If there is an option to do a direct stream copy of the video and only convert the audio then go for it.
Luck.Last edited by pcspeak; 22nd Oct 2011 at 16:21.
Convert AAC 5.1 to AC3 5.1
By ikarishinji41 in forum AudioReplies: 3Last Post: 8th Feb 2011, 02:21 -
How to convert a 6 channel aac to ac3?
By nasdravi in forum AudioReplies: 11Last Post: 15th Feb 2010, 23:01 -
Cannot Convert 6 Channel AAC to 2 Channel AAC - Help?
By Rez. in forum AudioReplies: 2Last Post: 3rd Dec 2009, 20:47 -
AAC to AC3 Wrong Channel Order
By midders in forum Video ConversionReplies: 12Last Post: 27th Nov 2009, 10:45 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23
