  1. Hello,
    I have a VMP70 which plays most of the files great. However, I noticed that there are certain mkv files which do not play at all(just shows black screen, but the duration of the file shows up on the tv screen). Thes files play ok on my PC. I can't figure out why there are issues with certain mkv files only? I have used mediainfo to derive information on a particular file which I was unable to play on my VMP70. Any thoughts?? Thanks in advance!!!
    Format : Matroska
    Format version : Version 2
    File size : 4.37 GiB
    Duration : 1h 33mn
    Overall bit rate : 6 713 Kbps
    Encoded date : UTC 2011-10-12 03:31:11
    Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
    Writing library : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5 frames
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 33mn
    Bit rate : 5 209 Kbps
    Width : 1 280 pixels
    Height : 688 pixels
    Display aspect ratio : 1.860
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.247
    Stream size : 3.30 GiB (76%)
    Writing library : x264 core 118 r2085 8a62835
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=5209 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 1h 33mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1 005 MiB (22%)
    Language : English
  2. The player may not like the header stripping (although the usual symptom is just refusing to play the file). Try a remux with MMG with the "Disable Header Removal Compression" option enabled. You have to exit and restart MMG after changing the option for it to take effect.
  3. "Thanks for the response. I downloaded the program mkvmerge GUI. But I was unable to see the option "Disable Header Removal Compression". Sorry for the newbie question...could you please elaborate as how to do this??
    Thanks!
    File->Options.
  5. File -> Options:
  6. Thanks a bunch!! After doing the above, I was able to view it on my media player.
