This has been solved.
Yesterday I downloaded the 30-day free trial of DVD lab pro, and have since put the video files into the program with a number of menus - it's a fairly basic DVD I want to make; nothing too fancy. I was following a guide, and had come to the end of it - and had pretty much put everything I wanted to in the DVD. Pressing the compile button, DVD lab gives a warning: "The project uses both 16:9 and 4:3 vidoes in a single VTS -> This DVD will be plaable, but it will play all vidoes -> in the same aspect as Movie 1 -> Normally you have to put each aspect video in a seperate VTS" as it's just a warning, and says it should play - I ignored this (as some other places say to do if you just get a warning there). Compiling it the first time, it came up with another error message - [ERR] wrong video vertical frame size. All my videos are the same frame size, and I had to alter it slightly for DVD-lab pro to accept them in the first place. I was hoping someone would help me, or tell me if there is a better way of solving this problem without re-changing the file sizes (as that would require reloading them, and making new chapters again). Would putting each video file into it's own VTS work? I've not been able to find anything online about it - or at least, ones that are in English. Any help would be much appreciated. Burig
Also: If the only way is to change the video size, what would the correct size be? Currently I have them at 720x576
if you select a pal template then 720x576 is correct, for ntsc it is 720x480.
you might try recoding your 16/9 video to letterboxed 4:3 with burned in black bars top and bottom. then the 16/9 won't have the sides cut off or display squished too tall and thin during playback.--
your encoder should have setting to output either 16/9 or letterboxed 4:3. they are both 720/576.
Sorry about the wait.
I'm using winff to change the files to mpeg
I've set the video size to 750x576, but can't see any other output settings;
the only ones there are are
preset: Pal DVD fullscreen, or Pal DVD widescreen (or high quality for either of them)
or Apsect Ratio.
Nevermind.
I'm stupid at times. n_n;
I also forgot: Thank you for the help!
Usually forums I find through google are fairly slow moving and don't get much attention, so was fairly surprised and pleased to get a fast reply!
I am very much appreciative.Last edited by Burig; 17th Oct 2011 at 11:46.
Dvd-lab Read Data Size
By Burig in forum Authoring (DVD)Replies: 14Last Post: 19th Oct 2011, 19:41 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 14:48 -
Frame made in dvd lab pro 2
By PharmBoy in forum Authoring (DVD)Replies: 5Last Post: 28th Apr 2008, 22:57 -
video size quadruples in dvd lab pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 1Last Post: 13th Mar 2008, 19:23 -
DVD (VOB) Frame Size
By Brosco in forum ProgrammingReplies: 6Last Post: 14th Jun 2007, 22:24
