Hi.
I use VirtualDub to correct audio delays in videos.
However now I have video which audio is both sync and out of sync. I mean, for some periods audio is correct but then it is not. So I cannot delay or shift the whole audio stream and would like shift/delay only selected period.
How to to this in VirtualDub ?
Thanks.![]()
Interleaving has nothing to do with sync. It has to do with how chunks of audio and video chunks are spread throughout the file, not when they are played. For example, you could have all the video frames appear before all the audio, but that doesn't mean the video is played first, then the audio is played. What determines when the two are played is the audio "skew" value. You can't change that in the middle of an AVI file.
And you can't fix that type of problem with VirtualDub. At least not very easily. You would have to cut it into different segments and adjust segments individually, then join all the segments back together again. -
Sorry, my mistake, I meant 'Audio skew correction' under 'Interleaving...' command in VirtualDub.
OK I see...thanks, I'll split video into parts and try to fix it. -
Yes, put VirtualDub into video and audio Direct Stream Copy mode. Use the mark-in and mark-out tools to mark sections of video on key frames. Then Save as AVI.
HcEnc: brief periods of pixelation
By unclescoob in forum Video ConversionReplies: 44Last Post: 11th Nov 2011, 17:37 -
MP4 video correction in audio
By onlygk in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2010, 01:08 -
MP4 video audio level correction
By drwho in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2008, 16:24 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 14:33 -
Any 1Click Blu-ray / HD-DVD method to extract selected Video/Audio streams?
By jmone in forum DVD RippingReplies: 3Last Post: 2nd Jan 2008, 10:12
