  1. Yo
    when I try to encode 2.0 channesl dts to .mp4 AAC extension (Nero AAC codec) with MeGui, I get instant error and the following in the log
    https://forum.videohelp.com/images/imgfiles/IEjN9.jpg
    what could be the problem here?
    I used to do this without any problems few months ago.
  2. NicAudio show this 'error in file' when found a DTS frame with invalid values.
    Maybe your file is corrupt or have a unusual config, please put a MediaInfo of the file.
  3. General
    Unique ID : 203565891891659855560961219905525665472 (0x99255D5BFF169BE0862EF201AA044EC0)
    Format : Matroska
    File size : 6.69 GiB
    Duration : 1h 42mn
    Overall bit rate : 9 310 Kbps
    Encoded date : UTC 2008-12-19 08:50:36
    Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Cover : Yes / Yes / Yes
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 42mn
    Bit rate : 7 530 Kbps
    Width : 1 200 pixels
    Height : 720 pixels
    Display aspect ratio : 1.667
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.364
    Stream size : 5.28 GiB (79%)
    Writing library : x264 core 65 r1047M f773bf0
    Encoding settings : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=7530 / ratetol=1.0 / qcomp=0.60 / qpmin=8 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.80
    Language : Chinese
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 1h 42mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.09 GiB (16%)
    Title : DTS 1536 Kbps
    Language : Chinese
    Audio #2
    Format : Vorbis
    Format settings, Floor : 1
    Codec ID : A_VORBIS
    Duration : 1h 42mn
    Bit rate : 80.0 Kbps
    Channel(s) : 2 channels
    Stream size : 58.9 MiB (1%)
    Writing library : libVorbis 1.1.1/1.1.2 (UTC 2005-03-04)
    Language : English
    Audio #3
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 1h 42mn
    Bit rate : 192 Kbps
    Bit depth : 16 bits
    Stream size : 141 MiB (2%)
    Title : AC3 192 Kbps
    Language : Russian
    Text #1
    Format : ASS
    Codec ID : S_TEXT/ASS
    Codec ID/Info : Advanced Sub Station Alpha
    Compression mode : Lossless
    Language : English
    Text #2
    Format : ASS
    Language : French
  4. Last edited by tebasuna51; 25th Oct 2011 at 07:04. Reason: Add solution
