Hi there, IM having an issues with Gotsent not adding subtitles when finished converting to a ps3 file. I used MKV Merge instead to merge the mkv and subtitles and the MKV is fine. But when I try to convert the subtitled version to a PS3 file I get an error that the mpeg was not created. Can anyone help? I really need subtitles.TIA!!! And hello to all!
When you use mkvmergegui be sure to disable header compression, under file->options.
Well the MKV was fine but the VOB is black with some squiggley green at the top.
Any thoughts?
GotSent Problem
By MultiNikos in forum Video ConversionReplies: 8Last Post: 29th Jan 2012, 16:36 -
Gotsent converstion problem
By Bigm1ke in forum Video ConversionReplies: 1Last Post: 6th Jul 2010, 22:08 -
GOTSent Problem
By zac5876 in forum Video ConversionReplies: 1Last Post: 28th Feb 2010, 12:36 -
GOTsent audio problem
By zunichi in forum Video ConversionReplies: 3Last Post: 9th Apr 2009, 21:46 -
Gotsent problem
By Ducco in forum Video ConversionReplies: 11Last Post: 8th Apr 2009, 21:07
