I am using a TviX N1 which has worked great so far playing my DVD mkvs. I just started experimenting with BluRay and the M2TS folder seemed to play choppy so I made a MKV encode with handbrake but the movie will only play in a fast forward mode. I can not adjust it but it seems to play fine on the computer without any sound.
No more details than that? Installed the required software?
The error log did not show any errors. It went through the demuxing streams for about 30 mins and said demuxing error. I am trying to run a 44 gb M2TS file keeping the core setting for HD audio and no subs. I tried installing WM11 which did not help.
Few n00b questions regarding backing up blurays ..
By ahmadka in forum Blu-ray RippingReplies: 0Last Post: 20th Apr 2011, 11:49 -
What do you use to play Blurays?
By Dexx in forum Software PlayingReplies: 9Last Post: 24th Jan 2011, 16:27 -
is there an easy way to get trailers off of my blurays?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 18th Dec 2010, 11:57 -
can you rip blurays and then remove audio commentaries without reencoding?
By krohm in forum Blu-ray RippingReplies: 2Last Post: 1st Mar 2010, 08:54 -
Looking for an app that will backup HDDVDs or Blurays with minimal effort
By AndyD in forum Blu-ray RippingReplies: 24Last Post: 5th Dec 2009, 12:48
