[SOLVED] 2011-10-26 Tue, xcm and cqm import the same way--different file ext but same format.
i'm doing some work with matrix manipulations for xvid encodes. i see that some xvid'ers made a few of their own and created them in an unfamiliar .xcm file format. notepad opens as garbage chars, and google searches have turned up nothing on the format or file structure, so i am left with the task of determining the layout and decoding them myself.
update on this endeavor..
so in the process, i've been working on a matrice editor utility and adding features as they come to me while debugging alternate matrice encodes. couple wishes i always wanted to have.. to scan through many matrices quickly without the repetitve open/search steps, and increment in steps or other means when adjusting matrice values. so far the first is complete.
Results 1 to 1 of 1
extract a matrice from an xvid avi file ? [SOLVED]
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2011, 09:14 -
Convert FLV-file with H264 format into xvid?
By mccm in forum Video ConversionReplies: 2Last Post: 8th Oct 2009, 11:54 -
SOLVED: Blocks in xvid output
By overtoast in forum Newbie / General discussionsReplies: 10Last Post: 9th Mar 2009, 06:50 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59
