Hi folks,
Does anyone know if its possible to seperate a 3D MKV file into two seperate files? ie: left and right eyes.
I have an MKV file that I need to reverse the frames on, as they play in the wrong order....
Basically need to swap left and right.
Thanks in advance.
The way MOST MKV 3d files are comprised are as the 2 anamorphic Side-by-side (SbS) images contained within a standard 2d video frame.
The way to separate them is to:
1. Crop in 1/2 horizontally (1st keeping the lefthand side)
2. Resize the remaining piece 2x horizontally, while keeping the vertical size the same
3. Export to separate file
4. Repeat steps 1-3 but keeping the righthand side
Like these 2 scripts:This can be done with any NLE or conversion app that can accept MKV's...AVISynth, Virtualdub, etc. (including apps that can accept AVS files).Code:OriginalClip = DirecshowSource() LeftHalf = Crop(OriginalClip, 0, 0, -(OriginalClip.Width/), 0) Left = LanczosResize(LeftHalf, (OriginalClip.Width), (OriginalClip.Height)) OriginalClip = DirecshowSource() RightHalf = Crop(OriginalClip, (OriginalClip.Width/), 0, 0, 0) Right = LanczosResize(RightHalf, (OriginalClip.Width), (OriginalClip.Height))
Or
You could skip that all and just watch the file un-reversed-and-exported by viewing in Stereoscopic Player and flicking the "reverse views" toggle switch. Or use AVISynth and a swapviews script*, frameserving to any player app that accepts AVS files.
Or
You could just watch the video as-is, and flick the "swap views" toggle switch that is available on (AFAIK) EVERY 3d tv. They're built with this contingency in mind.
*edit:Code:OriginalClip = DirecshowSource() LeftHalf = Crop(OriginalClip, 0, 0, -(OriginalClip.Width/), 0) RightHalf = Crop(OriginalClip, (OriginalClip.Width/), 0, 0, 0) StackHorizontal (RightHalf, LeftHalf)
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 19:56 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
mkv question... many mkv files (with subs) into 1 mkv?
By 0okami in forum EditingReplies: 1Last Post: 24th Oct 2009, 00:45 -
Seperating Audio Channels.
By vodmare in forum AudioReplies: 7Last Post: 14th May 2007, 16:33
