Hi
I have a PAL DV camera and I would like to burn an SVCD disk but with the NTSC format (for viewing in the US). How can you do it? I have VS6 and MoovieFactory.
Stelios
I'm not familiar with Movie Factory per se, but I can tell you that making a standard, ISO compliant NTSC SVCD will require the following settings:
*480x480 resolution
*2520kbps max (for standard SVCD, anything above spec may not be compatible w/ certain players)
*mpeg-2 video
*224kbps mpeg-1 layer 2 audio, 44.1Khz sampling rate (seems to be most compatible)
*29.97fps
Alternately, you could download TMPGenc from this site and use the standard NTSC SVCD template that is provided with that program. Otherwise, try those settings in Movie Maker, and if you have any further questions about SVCD or the standards for PAL or NTSC, look at the SVCD guide under the "what is" section.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
