i have a few questions actually one of them concern ntsc and pal what other then the resolution is the diffrence between the two and which is better? Also if you rip a ntsc dvd should you encode your mpg with a ntsc template using tmpgnec? Ok now I have another question When your setting your settings in tmpgnec and your setting your source aspect ratio and if you the source is a 2.35:1 what would you set the source at? i have many more questions but this is it for now thanks everyone for all your help
NTSC= video format used in North America and Japan
PAL/SEACAM=video format(s) used elsewhere
I am assuming from the style of your writing that you live in the US. . so use NTSC. While some players and TV's can handle both, I don't see any sense in creating discs in a different format than the one that is used where you live (I've made both and don't see any benefit to using PAL over NTSC). NTSC DVD's should therefore be ripped as NTSC.
Source aspect ratio: 1:1 (VGA). Also use Full Screen (keep aspect ratio); this will keep the video in the same aspect as the source, which means that on your TV, your final VCD will have black bars with widescreen sources and full-screen video with 4:3 sources, etc.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34
