Just a newbie question buy why are some radio stream stations louder than others?
Is it the player, way its encoded, bit rate or what?
note: Streamed using FF browser
Fuller and Richer Sound
http://provisioning.streamtheworld.com/asx/KROQFM.asx
Not as loud
http://live.cumulusstreaming.com/KFOG-FM
Thanx for the help, jaxguy![]()
Louder is just their choice at what volume level to use. "Fuller" is usually a matter of bitrate. The fuller stream you linked to is 96 kbps MPEG audio 44.1 KHz, stereo. The other is 49 kbps WMA2 44.1 KHz, 16 bit, stereo.
Roger that, thanks for the clairfication...
I owe u a beer Jagabo -
Jagabo..
Do you have a app to recommend that would check the Kb/s bitrate, Hz etc?
Is playback of mpeg-ps streams possible on a pc?
By craig198 in forum AudioReplies: 2Last Post: 26th Apr 2011, 11:12 -
GfD Subtitles - more than 3 streams
By GFDuser in forum SubtitleReplies: 1Last Post: 25th Apr 2010, 22:18 -
Stereo Streams
By Dave1024 in forum AudioReplies: 0Last Post: 21st Aug 2009, 00:54 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
Adding Richer Colors and Reducing Blurring
By xstein in forum EditingReplies: 3Last Post: 28th Mar 2009, 13:19
