This development just materialized earlier today.
HC Encoder apparently only encodes/processed the video fed into it leaving the orginal audio/.wav file intact.
I need a dvd compliant MPEG-2 file with MPEG- layer II audio.
AC3 audio doesn't work in my particular case.
What muxer/tool(s) are up to the task without re-encoding the video?
How would you solve this?
Thank you.
Convert/Mux .m2v and .wav into mpeg for DVD??
By Beavis in forum Video ConversionReplies: 2Last Post: 22nd Jul 2011, 15:46 -
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 23:25 -
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 07:10 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
