I'm trying to add a transition (Dissolve) however I want to extend the length of the transition, currently it's about 1 second and I want it longer...... how can I do this?
I've tried resizing it with my mouse but this just resizes the whole video.. or should I try and split it from the rest of the video and then resize it?
Thanks a lot!
options/preferences/editing
If you mean the "New still image" option then that is set at 5 seconds; however the transition I inserted is nowhere near 5 seconds; not sure why??
no. a new still image is a picture added to the timeline. try adjusting the overlap time in preferences and then adding the effect. or right clicking on the fade and adjusting it's properties. or control/click/drag the fade line.
What's with the transition in Vegas....
By Abas-Avara in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2009, 13:52 -
Problem with adding transition effects to HDV footage in Vegas 9 Pro
By btodorov in forum EditingReplies: 4Last Post: 24th Aug 2009, 14:46 -
Vegas 8 - Transition help
By stantheman1976 in forum EditingReplies: 14Last Post: 30th Aug 2008, 07:29 -
Using Pinnacle transition FX in Vegas?
By NoRulez in forum EditingReplies: 0Last Post: 9th Sep 2007, 12:59 -
using a book page turning transition in vegas?
By Rudyard in forum EditingReplies: 1Last Post: 11th May 2007, 04:06
