I have some MKV files I want to remove everything from except the video and main audio.
I've tried everything I can get from here but cannot find anything that can do this in one go.
I've tried splitting and re-merging using things like mkvcleaver/mkvmerge/toolnix/mkvstreamextractor etc
but nothing seems capable of re-merging and keeping the audio in sync.
Can anyone suggest a one step application that can strip all the extraneous stuff out of MKV files please?
(I'm not overskilled so a GUI app is far preferable)
cheers
Results 1 to 12 of 12
install the latest mkvtoolsnix. run mkvmergegui(mmg.exe). open file options and put a check in disable header removal compression. close mmg and then restart it. open your mkv with it. uncheck whatever you don't want and then give it an output folder and name. click merge.
if it's not in sync does the amount of delay vary or is it constant for the entire video?
if it's constant you can manually input a delay offset in mmg. you just need to figure out how much.--
As above, use mkvtoolnix only. Don't extract the streams, just uncheckmark the streams you don't want, leave the audio & video checked. If you extract it, that's when sync problems can frequently occur
If you still get sync problems then there's a problem with the original mkv.
Thanks guys
I've tried that with mmg.exe and it works great. (I didn't understand what that header
setting did when I tried it before and that seems to be what I needed)
Just to keep me amused the TV bug that was forcing the subtitles on isn't the only problem I have
It seems it cant play DTS files so I now have to convert to AC3 or something anyway.
I do feel like I'm running round in circles here! -
Been there done that! The next step is https://www.videohelp.com/tools/PopCorn-MKV-AudioConverter
PopCorn MKV AudioConverter is a Matroska MKV DTS to MKV AC3 converter. It can also remove DTS tracks and convert OGG audio to AC3,MP3,AAC,MP3. It requires a lots of external tools but AudioConverter will download them automaticallySONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Cheers netmask I'll give that a go.
Dont you just love it when a plan comes together
This procedure has been a problem for me with my Theater+ media players. They will not play mkv files that have been muxed in this way.
I have to extract the streams I want and if I want any additional streams I have to use MMG to add them as well as the original streams.
Tony -
OK some feedback after messing with it all weekend:
Everything (except AAC) plays fine on all my PC's (I have 4 all different)
However I have a great deal of trouble when playing back via Bluray player USB port or from the TV directly.
Most MKV's play fine but the ones I create myself always have issues.
I have discovered that I DONT need to change video or audio formats but simply putting then in a .TS wrapper
cures 95% of issues
HOWEVER using "makeMKV" is a dissaster - it never works and trying to change it causes sync issues.
Using most of the free software sends me round in cricles - none of it seems to do what I really want and most
of it doesnt work on playback off a PC.
The best solution I've found to doing my DVD's so far is:
1. Use DVD decrypt to hard drive
2. Use mmg.exe and manually select the movie vobs to append
3. Use TSmuxerGui to change the MKV to a .TS stream removing subtitles if necessary
Unfortunately the TS stream will then refuse to "seek" on playback and I cant get any chapters to work
even if I include them.
I'd appreciate any suggestions for an easier way to do what I want or to get the searching and or chapters to work
at any time.
cheers.
PS the playback is via USB hard drive through an LG BD660 bluray player -
In version v6.2.0 (Promised Land) I currently have it has been removed, however if you load a file and highlight the video and then go to "extra options" tab you can then select none - repeat for the audio etc. It may be defaulted off but I haven't been able to find any update notes.
Header Removal Compression was disabled by default quite a few MKVMergeGUI versions ago. Therefore the box to disable it's use was removed. I assume it was causing too many problems. I could never really see the point myself.
If you open an existing MKV with the current version of MKVMergeGUI and just remux it, the output file shouldn't use header removal compression even if the original MKV did. The ability to manually enable it per track can still be found under the Extra Options tab.Last edited by hello_hello; 30th Dec 2013 at 00:32.
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 02:06 -
Remove any subtitles has an mkv file.
By fits79 in forum SubtitleReplies: 6Last Post: 4th Aug 2011, 16:49 -
Trying to remove subtitles from a mkv with mkvmerge
By vato76 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2010, 22:53 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 10:21 -
Remove video from MKV to cut into smaller files
By martylavender in forum DVD RippingReplies: 6Last Post: 12th Nov 2008, 10:58
