Hi, About to recieve my Beagle xM next week. can I interface my VGA monitor through a HDMI-DVI-D cable via DVI-D to VGA adapter?
vinny88-in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time.
http://www.kiva.org/about -
The .pdf manual for the Beagle XM says thie "The analog portion of DVI, which provides RGB analog signals, is not supported by the BeagleBoard. Buying a DVI to VGA adapter connector will not work on a VGA display. You will need an active DVI-D to VGA adapter." So, you need the active adapter or a new monitor with DVI or HDMI input.
A typical passive DVI-I to VGA adapter won't work. HDMI is digital only. It is electrically compatible with single-linked DVI-D, but does not have the extra pins needed to support analog output that a DVI-I connection would have.
My monitor won't switch from vga to dvi?!
By fran-man56 in forum ComputerReplies: 12Last Post: 4th Apr 2012, 23:08 -
Need help from video experts, hdmi to vga to dvi
By edgarmiranda in forum Newbie / General discussionsReplies: 3Last Post: 20th Jun 2011, 22:24 -
VGA to DVI cable?
By mr-scarface in forum Newbie / General discussionsReplies: 8Last Post: 11th Mar 2011, 16:39 -
VGA to DVI-D cable
By ljCharlie in forum DVB / IPTVReplies: 22Last Post: 13th Jan 2010, 13:07 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 20:37
