Results 1 to 15 of 15
  1. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Trying to stream direct the below link for The Eagle WEKL 105.7
    http://www.iheart.com/live/753/
    But it uses a proprietary stream thru iHeart
    If anyone has any experience with iHeart and can figure source URL out
    I would greatly appreciate it!
    JaxGuy
    note: The above link only works for me with Firefox not IE
  2. RtmpExplorer can download from there. It shows the URL as:
    "rtmp://cp19785.live.edgefcs.net/live/" -a "live/" -f "WIN 10,3,181,34" -W "http://www.iheart.com/_/973003a0/flash/fp/flowplayer.ihr-3.2.6.swf" -p "http://www.iheart.com/" --live -y "Sdi_CA_KHTS-FM_OR@s7843?auth=daEc6bIa5brcydicYaybVbfaRb4dHbhdh cG-boLV95-4q-TM1V7_8ppGIpm1GBukArzq&aifp=1234&CHANNELID=241&CPR OG=SIMULCAST&MARKET=SANDIEGO-CA&REQUESTOR=KHTS-FM&SERVER_NAME=service.ccrd.clearchannel.com&SITE_ ID=829&STATION_ID=KHTS-FM&MNM=2&TYPEOFPLAY=0&terminalid=152&uid=0&init_id =8169&profileid=0&fb_broadcast=1&at=0" -o Sdi_CA_KHTS-FM_OR@s7843.flv
  3. Member bat999's Avatar
    Feb 2008
    Hi
    That stream uses RTMP method.
    It won't play with a media player straight off.
    It needs to use RTMPDump.
    (Or RTMPExplorer if you need a GUI)
    With RTMPDump the stream can be saved to a file.
    Also the stream can be piped to VLC.
    RTMPDump for Windows is here:-
    http://rtmpdump.mplayerhq.hu/download/rtmpdump-20110723-git-b627335-win32.zip
    This is the command I used to download the stream to a file:- http://pastebin.com/SssQMDyU
    This is the command I used to pipe the stream to VLC:- http://pastebin.com/7PJG3UyY
  4. Member bat999's Avatar
    Feb 2008
    EDIT
    The Eagle link keeps changing.
    So for Windows users RTMPExplorer is probably helpful to find it each time.
    From here:- http://all-streaming-media.com/record-video-stream/RTMPExplorer-freeware-GUI-for-rtmpsrv-Windows.htm
    Good music from that station too.
  5. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Probably something simple that I am missing but these are the screen errors I am getting
    -When attempting to play via VLC I get the following with failed error at end
    RTMPDump 2.4 git-b627335 2011-7-23
    (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
    Connecting ...
    INFO: Connected...
    ERROR: Closing connection: NetStream.Failed
    -When downloading with Vlc, will create a .flv file then I gegt the following streamnot found error
    the file by the way is 0 bytes..
    Connecting ...
    INFO: Connected...
    ERROR: Closing connection: NetStream.Play.StreamNotFound
    Press any key to continue . . .
    So, I have not been able to play as of yet, what am I doing wrong??
    Thanks Guys for all the help ...
  6. Member bat999's Avatar
    Feb 2008
    Hi
    There's a link for Eagle-105.7 that doesn't need RTMPDump here --> http://pastebin.com/ZJKGqaST
  7. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    bat, Your good man!
    How in the heck did u figure that out, if u don't mind me asking...
  8. Member bat999's Avatar
    Feb 2008
    How in the heck did u figure that out...
    Hi
    The information is from (post #15) in this thread here --> http://stream-recorder.com/forum/record-clear-channel-radio-stations-iheartradio-com-t6306.html
    put your station call letters in the appropriate place and run thru VLC Player and then go to "Media Information" tab and it will give you the akamai stream...
  9. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Thanks 4 that info bat...
    Now how did you come up with the Akamai Stream numbers which are for Eagle 105 - /7/768/25770/v1/ ??
    Jax
  10. surfmusic.de has lots of good stuff.
  11. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Thanks for the link, I still need to find out how bat came up with the Akamai Stream numbers for Eagle 105 - /7/768/25770/v1/ ??
  12. If you look at surfmusic.de you can see that all the links have the same format:
    _http://www.surfmusic.de/media/kiis-fm.m3u (KIIS-FM-102.7 Los Angeles)
    _http://www.surfmusic.de/media/whtz-fm.m3u (WHTZ-FM-100.3 Z100 New York)
    _http://www.surfmusic.de/media/kfi-am.m3u (KFI-AM-640 Los Angeles)
    You can use the same format and substitute the Eagle FM call letters:
    http://www.surfmusic.de/media/wekl-fm.m3u
    That downloads an M3U playlist. Open that playlist with NotePad and you'll see it contains the URL:
    http://wekl-fm.akacast.akamaistream.net/7/768/25770/v1/auth.akacast.akamaistream.net/wekl-fm
  13. 2 years late but w.e
    was bored today and wanted to listen to a local radio, so i spent the 5 minutes to figure out iheart.com's url scheme
    1) go to any iheart.com radio station.
    2) look at url. should look like /blah/blah/live/305/ or /blah/blah/live/STAR-1013-281/
    3) station id is last number, so 305 for first example and 281 for second example
    4) go to http://www.iheart.com/a/live/station/<insert station id here without the carets>/
    5) shoutcast url is right there, just remove extra \
    if they ever change it:
    1) look at their minified js (tusiq.js)
    2) look for the class of the play button. See what function it's hooked to (they use jquery)
    or
    2) look for station object, with functions like loadStation, etc.
  14. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Thanks for the info and you are never to late, may always help someone else.. JaxGuy
  15. Banned
    Freedonia
    You do NOT speak for the majority of members here with that statement. I'd say that while this particular example of adding to an older thread is OK, it's not something we like or recommend and the vast majority of additional posts years later are pointless. Your enthusiasm might be a bit more restrained if you saw as many threads as I have that have been dug up from their graves years later to do the following:
    The new post says "Thanks for helping me". Imagine what it would be like if EVERY thread had people doing this.
    The new post simply restates exactly what others have previously said and offers no new insights of any kind.
    The new post asks questions of the original poster, who hasn't logged in here in years.
    The original post didn't have some question answered (probably just an unlucky case of a post that just got ignored - it happens), but since then we have had numerous other posts on the same subject that contain more information and answer the question there and the new poster is convinced that 8-10 years or even more later, everybody in the original thread has never learned to do what the thread was about and we've all been waiting for years for him to be the first person on earth to help us get over that hurdle.
