Results 1 to 13 of 13
  1. I have a source video with the dimensions 1280x694
    If i upload the video as is on youtube will it offer it in 720p?
    I'd hate to go encoding it again just to stretch it out so it meets specifications..
  2. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Since one dimension is "HD" it might well work, but they will letterbox it for sure.
    That's a good question, actually, since YT has preset display resolutions. The question is if your video is larger that 480p (or one dimension is), will they bump you up to the next size, which is 720p.
    Why don't you try it, and post back.
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    If height is 1280 = 720p
    If
    width is
    720 = 720p
    My video below is 1280x480 = 720p
    Claudio
    Mar 2008
    Interesting ... the above video is not letterboxed - looks pretty good.
  5. Banned
    Nov 2005
    If
    width is
    720 = 720p
    bzzt, wrong answer. 720p is defined as 1280x720 with progressive scan, anything else is not 720p.
    the video you post, the one on the left looks fine, they one on the right looks retarded (it looks "squished"). 1280x480 doesn't come close to equaling 720p unless you drop significant amounts of acid on a regular basis.
  6. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I'm confused why You tube shouldn't reject 720x694... What is that?
    720p is square pixel. Youtube wants 30p (29.97p)
    http://www.kiva.org/about
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    For Youtube my friend, for youtube...Only this. Check the first post...
    About videos: Sega Genesis source is 320x224 (left), Snes source is 256x224 (right). T
    his video shows the difference in resolution for both.
    Another 1280x480 video:
  8. Member edDV's Avatar
    Mar 2004
    Um socio-political loaded. Dems want protart car(art) and we left wants to Zero Netflix or tax it.
    Either way cable will respond to a cable discsonnetc.Ytat onlyworks fomet me it locals ncontrol but now the dem control wired
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    earth to edDV.... earth to edDV.... come in please? how high are you?
    Oct 2010
    England
    From the tests I've done and what others have said in the past, YouTube:
    1. re-encodes all uploaded videos
    2. requires that videos have square pixels*
    3. will make use of the display aspect ratio flag to determine (2.)
    *Divide your video's width by the height. If the number you get doesn't match the display aspect ratio flag, your video doesn't have square pixels and YT will resize.
    DAR / (width / height) = PAR
    DAR = display aspect ratio - final shape of the picture
    PAR = pixel aspect ratio - shape of each pixel
    It doesn't matter if the uploaded video isn't one of YT's common resolutions (640x360, 854x480, etc) as long as the pixel aspect ratio (PAR) works out to 1:1
    So, if your 1280x694 video has an aspect ratio of ~1.84:1 it won't be resized. If the AR is set to 1.78:1 (16:9 for example), YT will probably resize to 1280x720.
    Only you know what the AR should be - make sure it's set correctly.
  11. Member edDV's Avatar
    Mar 2004
    None of that looks familiar. Not even the context. Have I been hacked? Going to reboot and scan.
  12. Member edDV's Avatar
    Mar 2004
    Seems to be from house guests on an open downstairs computer. I still don't get what they were trying to say.
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    hehe. i can't tell either, but it sure looks like they put a big dent in your secret stash
