I visited a.b.vcd and downloaded a movie. It extracted to a .bin and .cue files. What exactly are these files? Can I just copy them to a CD to view on a VCD player?
How can I convert these to a AVI or MPG or just watch these on my computer? I searched vcdhelp.com but couldnt find anything on what these files are.
TIA
Coasterdude
See that "How to" section to the left side of the site?
Click on "convert", then scroll down, you'll see what you are looking for.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
bin an cue file are formats in which u use to burn with software such as cdrwin, fireburner. u can also use nero to burn these file. if u want to watch it in ure computer use iso buster to extract the mpeg file. if u want to watch it at ure dvd player be sure that ure player supports vcd and what media it supports check the dvd players compatiblity list in this site.
If you want to view the video before you burn it, use Daemon Tools to mount the image in a virtual cd rom and play it with your pc DVD player. Then to burn it simply use the disc copy function in any cd mastering software you have....Nero, CloneCD, Blindwrite, etc.
Daemon Tools is free, you can get it here: http://www.daemon-tools.com/daemon_tools.htm
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
