Hello,
I have a flv-file with non-synchronous audio and, as of this, splitted it into video and audio-stream using a prog named "FLV Extract".
Now I have a *.264 (video) file + *.aac (audio) file which I would love to combine to a playable videofile.
Which prog can bring the two streams together to one file (which is supposed to have synchronous audio then)?
My TMPEGEnc doesn't 'like' the audio file very unfortunately
Any help is gratefully appreciated![]()
video-fan
Hi
Try with YAMB to make an mp4 file.
Yamb-2.1.0.0 beta 2 with installer
From here:- http://yamb.unite-video.com/download.html -
ANd you must adjust some delay if you want to resync it. Just split/demux and join/multiplex wont help.
And this is not any vcd authoring. Moving you. -
video-fan
Windows 98. Eeeeek.
Perhaps:
MP4Box.exe -add "input.264" -add delay=200 "input.aac" "output.mp4"
It may do it. You end up with an MP4 and not a FLV but......
p.s.
If you have Win98 SE and don't have Windows 98SE Service Pack 2.1a.exe
I suggest you find it on the web and install it. Not an official release but well worth it.
Please do a backup of your system first.
Good luck.
Editing MP4 files with H.264 (AVC) video and AAC audio
By Ahari in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2012, 16:30 -
How do i combine a video file and audio for two different movie sources??
By Kyisha in forum Newbie / General discussionsReplies: 3Last Post: 22nd Mar 2010, 06:03 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
Hi can anyone tell how to play a mp4(h.264 + AAC) file using dshow filter?
By kalpanaanb in forum Newbie / General discussionsReplies: 1Last Post: 31st Mar 2009, 08:58 -
How to combine video with audio file and replace audio with video files ?
By designbuyers in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 11:12
