This is my first time in this forum and this is the closest forum to the problem that I'm having. If this is posted at the wrong location I apologize.
Here's my problem
I downloaded a divx file which is 200+ megs. I then followed the rules of Divx to vcd conversion at DIGITAL DIGEST and VCDHelp
These are the options that I followed which I borrowed from DIGITAL DIGEST.
Stream type: Mpeg-1
Size: 352x240 (must be this size!!)
Aspect Ratio: 4:3 525line (this can vary depending on the rip and the dvd player- but 4:3 usually works best)
Frame Rate: 29.97fps
Rate Control Mode: Constant Image Quality. Then go to the settings and change the quality to 100 and the maximum bitrate to 100 000.
Motion Search Accuracy: Highest Quality (very slow)
Advanced tab:
Source aspect ratio: This can be changed depending on the rip that you have. Try to find out the aspect of your rip. Otherwise pick one at random as this does not seem to make THAT much of a difference usually.
Image Positioning Method: Fit to Frame (preserve aspect ratio)
In the area below, select the following boxes- Ghost Reduction, Noise Reduction, Edge Enhancement, Basic Colour Correction, Crop Video, Audio Effects
Audio tab:
Stream type: Mpeg-1 Audio Layer II
Sampling Frequency: 44100 (must be this!!!)
Channel mode: Stereo
System tab:
Stream type: Mpeg-1 Video CD
There are no problems when I run the finished VCD in the computer. The problem lies when I play it on a Pioneer VCD player. Varying degrees of occassional pixellation and audio popping occurs when the VCD is played on the VCD player.
My VCD player can play most vcds that I haven't created. I only encountered this problem once on a vcd that I bought. I also set it to NTSC (the only working setting).
Please help. This is the first time I created a vcd.
Results 1 to 1 of 1
avi file from hypercam is flickery when played in dvd player on tv
By west1745 in forum Video Streaming DownloadingReplies: 6Last Post: 10th Oct 2008, 13:17 -
Need help burning a 700mb file onto a disc to be played on DVD player
By chaoscreater in forum Video ConversionReplies: 7Last Post: 11th Jul 2008, 04:20 -
Gray shade in subtitles when [b]avi[/b] file is played in standalone player
By huRO in forum SubtitleReplies: 2Last Post: 1st May 2008, 14:15 -
VCD problems (playing using VLC; no menus in Media Player)
By pwhyles in forum Newbie / General discussionsReplies: 15Last Post: 17th Jan 2008, 13:16 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
