  1. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Here's the address or the player:
    http://radio.securenetsystems.net/radio_player_large.cfm?stationCallSign=WJXL
    Ideally, I'd like to play the stream of the url to OpenWebRadio on my Smartphone while on the go if possible. Can any of you gurus find a way?
    Thanks!
    JaxGuy
  2. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Thanks Jagabo,
    but when trying to open link in IE or FF says: WJXL Unknown File Type or
    attemps to download then says MIME Type: video/x-flv
    How do I use Wmp to just start playing off the link?
    I am assuming this is a flash file but my radio player wont accept it
  3. VLC will play the URL with its "Open Network Stream" option. WMP doesn't seem to work. It gets stuck at "Opening media". It's an AAC audio stream, if that helps.
  4. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Jagabo your the bomb!
    I got it to work finally, I used Foobar2000 and pasted the link in then saved it as .mp3 file then installed
    GSPlayer and TCPMP to my windows phone and both played the radio stream great. Also TCPMP would play
    it as a flv file with the flv plug-in installed.
    Thanks again, JaxGuy
  5. Member JaxGuy's Avatar
    Oct 2011
    Jacksonville, Fla
    Correction, I saved it as a .m3u not mp3... my bad
