i have 5 parts of MPEG files from Different videos (video size is different)
now i want to join that part and make a one big MPEG file any suggestions ?
Results 1 to 13 of 13
As the sizes are different must you reconvert. Add all mpgs in freemake video converter, choose join files at top right, convert to mpeg.
copy /b file1.mpg + file2.mpg + file3.mpg + file4.mpg + file5.mpg filebig.mpg
simplest way and it should work quite well but if You want perfect then demux ES, change timestamps in each ES in way that there is full continuity, add binary as in my example, similar in audio, then create Program Stream -
It wont work if the video size/resolution is different.
It's from the command prompt(Run->cmd). BUT it wont work if the video size/resolution is different! All properties must be same then.
thanks for pandy to quick reply
and mega thanks to Baldrick,
my problem is solve i use the free make video converter(for size issue) & then use fast avi mpeg joiner 1.1.2 -
Well - it just mean that player is poor - MPEG closed GOP is all You need to decode sequence - lot of broadcasters can change resolution and parameters (for example signaled aspect ratio, quantization matrices etc.) dynamically in real time and decoder must follow those changes immediately (usually nearest VBLANK). You can have some issues when open GOP is used (B frames can be lost at beginning).
Best MPEG-2 trimmer/joiner?
By dorenhagen in forum EditingReplies: 5Last Post: 31st Jan 2011, 10:45 -
AVI Joiner
By vipertongn in forum EditingReplies: 10Last Post: 25th Oct 2010, 17:42 -
RM Joiner
By nic3 in forum EditingReplies: 2Last Post: 8th Sep 2009, 05:24 -
Vista compatible mpeg joiner where 2 clips have diff dimensions?
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2009, 13:14 -
Converter/Joiner?
By Steph-x in forum EditingReplies: 0Last Post: 28th Jun 2008, 10:52
