I've worked with Premiere Pro CS4 for quite some time, definitely not a noob. But I can't seem to get the proper export settings I need for a specific project I'm working on.
Here are some details:
My sequence dimensions are 1920 x 680 (a custom size). After I've worked out my timeline and everything is exactly as I want it, I enter the export settings menu.
Here is a list of all the options:
H.264
TV Standard: NTSC
Frame Width: 1920
Frame Height: 680
Frame Rate: 24
Field Order: None (Progressive) *Grayed out
Pixel Aspect Ration: Widescreen 16:9
Profile: Main
Level: 4.2
Bitrate Encoding: VBR, 1 Pass
Target Bitrate: 32
Maximum Bitrate: 40
Set Key Frame Distance: Unchecked
Now, the problem is, when I export it with the 1920 x 680 settings, my video includes a black border on top and bottom, and the video is stretched. Instead of displaying the video with the correct proportion.
I need it to export at the same frame height and width as my sequence. But it always seems to include a black border on top and bottom. I've tried a ton of variations but nothing is working...
Thoughts?
Results 1 to 1 of 1
Custom Export Settings (Premiere Pro CS4) *Height
By BoLane in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 24th Jul 2013, 19:47 -
Samsung HMX200 Footage & Premiere Pro CS4 Problems
By gs1 in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2010, 23:32 -
Best export settings in Adobe Premiere CS4
By Polesch in forum Newbie / General discussionsReplies: 5Last Post: 5th Apr 2010, 17:45 -
Crop video on premiere cs4 and export as flv
By v1p0n3 in forum EditingReplies: 2Last Post: 27th May 2009, 14:07 -
Premiere Pro CS4 - export to MKV?
By nitrous in forum Video ConversionReplies: 10Last Post: 12th May 2009, 14:10
