Hello
I'm wanting to Extract Text from PDF. Not in the way you would use acrobat reader where you can copy image to clipboard, in a way you could take out words or letters or change around whats been written.
I have used a software that let me do this in the past but cannot remember name. It copied the page and turned black and i just extracted the text.
Any help would be great.
acrobat has it's own text editing tool. reader might also.
As above Adobe Reader allow you to mark text which you can 'copy' and then paste in to any text editor.
However, this only works for real text. Some pdf's are images of pages of books and adobe will not recognise the underlying text as such. -
True DB83, but a good operator with Acrobat Pro would use its OCR function to convert that to text. If the user only has Reader, though, they're SOL.
Unless you want to paste the image into a standalone OCR package, convert it to text, (proofread/edit it) and then copy out the sections that you want...
Scott -
FreeOCR will convert PDF to txt....but it is OCR.
However, you don't have to do any cut and paste. The program will accept PDF and convert it.
tony
Extracting text from .caption file
By dan2004 in forum SubtitleReplies: 3Last Post: 17th Nov 2011, 12:41 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 17:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
