Hi all,
I am making a bluray disc for my personal use out of movie clips ripped from original blurays, my personal HD videos and HD audio clips. So far, I have used DVDFab bluray to extract chapter I want without any encoding (untouched .m2ts) and then using Smart cutter have trimmed it perfectly according to my preference of the scene.
Now I have video clips in .m2ts format with DTS-HD and Dolby True HD audio formats. Likewise, I have HD audio clips in uncompressed wav which are 96Khz/24 bit.
I now need a software which can create bluray disc out of my media with variety of menus, sub-menus etc for easy interaction of bluray. If the software can make snapshots of the clips by providing a thumbnail preview with respective titles & text for the menus would be exceptional.
I had an opportunity to use Scenarist BD in my friend's laptop, but I feel its too complicated and not getting into my brains. I would rather require a simple software (economical) which can do the above job easily.
Thanks in advance...
I don't think you will find any "simple" blu-ray authoring with dts hd support.
Have you tried multiavchd? Probably not the simpliest authoring then but it support most formats like dts-hd. -
Hmm...I tried multiavchd and felt it is bit complicated to my knowledge. Any other user friendly software available if not complicated?
How to create playable DVD9 onto bluray from .iso file
By WareISChris36 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jul 2011, 06:54 -
How to create a BluRay from odd format videos and not distort the picture?
By Peterk312 in forum Video ConversionReplies: 5Last Post: 16th Jul 2011, 21:49 -
How to re-author back to bluray from BDMV bluray structure?
By eummagic in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Dec 2010, 22:14 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18 -
Bluray to dvd ( include menus )
By pcb in forum Blu-ray RippingReplies: 7Last Post: 26th Apr 2010, 21:35
