will it need 3rd party software just to do that?
is there any tmpegenc and virtualdub for OS X or equivalent?
i've heard the same by i've put it aside as crap, quicktime can read mpg, vcd is mpg, osx has quicktime. as to the encoders and such i don't know of any free ware soft that do that on a mac, you might consider either a pc emulator or terran's media cleaner pro.
The freeware MPEG-1 encoder I used before I acquired Toast Titanium is called Movie2MPEG.
As for a non-freeware solution, Toast Titanium includes a VCD encoder. The trick is, your Quicktime file has to be 74 minutes or less, or Toast will not bother to encode it.
A hard-to-find (but really, its easy to find!) solution that will make Toast-ready files is Astarte M.Pack. -
One other way to watch VCDs on a Mac running on OS X is to reboot back to OS 9 ad then open the files. For some reason I am unable to fathom, QuickTime is perfectly able to let you watch VCDs in OS 9 but not in OS X. Alternatively, you could do as I did and cough up about $20 for an app. like MacVCDX. It has the advantage of letting you watch your movie in full-screen mode and gives slightly better picture quality.
Monitor - "can't play 24p video" . . . Is this true?
By bweath in forum ComputerReplies: 10Last Post: 12th Jun 2010, 15:02 -
Formate/specs for video file which play smoothly Across G4 MAC/ PC /MAC PRO
By krijes in forum EditingReplies: 1Last Post: 2nd Apr 2010, 06:18 -
1080p true hd to 720p true hd possible ?
By miss in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 22:48 -
help tvix 6500 wont play true hd how do i convert
By lodwales in forum Authoring (Blu-ray)Replies: 5Last Post: 21st Mar 2009, 08:45 -
Sony .MPG files don't work on Mac? Is that true? Can I convert them?
By zernalaw in forum MacReplies: 2Last Post: 30th Nov 2007, 14:15
