  1. To put it simply, I have tried to use MKVExtractGUI to extract the ".ass" subtitle from an MKV file, I target my MKV and this problem pops up "Access violation at address 004EB324 in module 'MKVExtractGUI.exe'. Read of address 0000000D."
    I really have no idea how else I can remove the subtitle file from the MKV, nor any idea on how to fix this issue.
    Any help will be appreciated.
    Use mkvextractgui-2. Or maybe you mean it ?
  3. I was using MKVExtractGUI-2, I just noticed however, that it seems to not be able to play the MKV atall, I copied it from my brothers and now it works perfectly.
    It seems to me that the copying had an error or something rather than the actual MKV being faulty, thanks for replying :]
