Ok I have a brand new computer and it was recognising discs fine but just tried to put in empty and full discs that play perfectly well on my laptop and it just keeps saying insert disc?
Checked the device and it says it is working correctly checked device driver and that is up to day...really strange...
Optiarc DVD RW AD-7260S ATA device
Kriss![]()
Results 1 to 9 of 9
That drive you have is a Sony/Optiarc drive. Try changing the SATA cable.
http://www.seagate.com/ww/v/index.jsp?vgnextoid=2b089d2c3c90e010VgnVCM100000dd04090aRC...D&locale=en-US
If you have to ask instead of just looking up how to do it, I'm not going to hold my breath that you'll be able to do it yourself. You can try budz' suggestion, but I suspect the problem is with the drive itself and if so then changing the cable won't help. -
It's a laptop so forget about the SATA cable, laptop drives suck so buy an external USB writer. Just for the hell of it go to Device Manager and uninstall the drive, reboot and see if that helps.
I am not familiar with this drive so if MOVIEGEEK is correct and the computer in question is a laptop, you won't be able to do any of the work yourself for sure to replace the drive or cable. You'll have to either pay for repair or buy an external drive as he suggested.
I have put in disc drives before with a friend helping...just need to know which sockets and such like...I am actually an electrical mechanical engineer and used to build mobile phone base stations for a living for Nokia...LOL...but if you have never done it you are still not going to know how...LOL
It is in a workstation not a laptop...with 4gb ram and 1TB disc space so it should have a sata cable connector...will look into it at the moment using the laptop which is handy but would like to use the workstation as it is quicker than the laptop.
I will try to take out the drivers and see what happens...
Thanks guys for all your help
Kriss
Several DVD-Video discs on ONE Blue-ray disc
By nharikrishna in forum Authoring (Blu-ray)Replies: 6Last Post: 24th Oct 2011, 18:45 -
Disc info prior to buying the discs
By lbeck in forum MediaReplies: 5Last Post: 30th Apr 2010, 00:10 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 04:18 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 21:24 -
DVD Drive Freeze on certain discs (Different brands)
By Myrdek in forum DVD & Blu-ray WritersReplies: 10Last Post: 4th Aug 2007, 14:59
