Hi
I've read a lot on this forum and found some very useful info!
I have a HD PVR and the problem I am having is the m2ts/ts files that I get are sometimes showing up with incorrect durations. For example I have a ~10GB m2ts file which should be a few hours long that I've recorded off my Sky box which is showing up as only 8 seconds long. If I open in VLC I can watch it all the way to the end, but I want to edit it to be able to remove the commercials or any guff at the begining and end of the film.
Every program I've tried to use to edit it, also only shows a duration of 8 seconds.
I can't find anything on how to fix this, anybody able to help me?
The ffmpeg step to demux worked!
Also opening the file in MPEG Streamclip (which detected and repaired the errors) and then saving the file out again worked. I haven't got quicktime pro/alternative installed so couldn't see any video to do any edits.
Now I just need to find the best (free) cutting software. I used the trial of Transport Stream Packet Editor which was good. At least now the ones I do try can see more than 8 seconds of footage
Thanks for your help guys.
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 10:04 -
Hauppauge HDPVR w/ EyeTV
By xc5000 in forum Capturing and VCRReplies: 1Last Post: 18th Nov 2011, 10:22 -
Problems authoring TS files from Hauppauge HDPVR
By Subliminal in forum Authoring (Blu-ray)Replies: 10Last Post: 15th Sep 2011, 11:35 -
HDPVR, need help bad!
By James5955 in forum Capturing and VCRReplies: 26Last Post: 10th May 2011, 11:58 -
hauppauge hdpvr fiddling
By Splynn in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 15:00
