I'm going to Nigeria for a work assignment. I purchased a slingbox HD so I could watch US TV from Lagos. It requires a minimum of 384kbps for SD streaming, 1.5 MBps for HD streaming. I've heard that download speeds in Nigeria is considerably less. Can any of you make a recommendation or give me guidance on how I can capture the stream and play it back later? At this point, hardware will not be a problem. I have a Dell XPS laptop, Win7 Home Premium OS, Intel Dual Core T7200 @2.0 GHz, 2 GB RAM, 32 bit. I will get what I need.
Doesn't the Slingbox stream live video? Where are all the bits going to be saved while your slow pipe downloads? It's like saying you want to open a fire hydrant and sip the water slowly with a straw. Most of the water is going to down the drain.
You'll need to find a way to save the slingbox output to an intermediate storage device. Then sip slowly from that. -
Jagabo, that's the rub. Because Nigeria probably has slower download bandwidth than required, I'd like to capture it as it comes in and send it to a buffer for later retrieval. I just don't know how all of this works. Any ideas?
slingbox owners? are you happy?
By buzzinhornets in forum Media Center PC / MediaCentersReplies: 4Last Post: 18th Mar 2011, 07:33 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Slingbox
By didikai in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2008, 18:54 -
Slingbox and 360
By ArcticMark in forum Capturing and VCRReplies: 0Last Post: 3rd Mar 2008, 01:36 -
HAVA vs. Slingbox
By RoganSarine in forum Capturing and VCRReplies: 0Last Post: 2nd Jan 2008, 19:29
