    Oct 2011
    india
    I want to locate the offset of a frame from the mkv video file.
    Is there any media player or plugin which displays the offset number(decimal) of the current frame when i pause the video ?
  2. VirtualDub can tell you on the status line. It's in hex though. You can use a hex calculator to convert to decimal if necessary.
    6BFDA82 hex = 113236610 decimal
