Results 1 to 12 of 12
  1. How can I playback and edit 10-bit encoded videos in Premiere Pro CS5? The colors are messed up.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Where did you source 10 bit x264?
    You can convert it to 10 bit MPeg2 YCbCr or better 10 bit Cineform Neo if you need to do serious editing.
    http://www.kiva.org/about
  3. Some anime fansubbers are starting to use 10-bit encoding for more efficient compression. Anyways, I can play them just fine with MPC and CoreAVC 3.0
    I'd rather not to have convert anything... just doing some simple cutting and splicing.
  4. .mts File Hater JohnnyGalaga's Avatar
    Jan 2011
    USA
    What does "10 bit" and "MPeg2" and "YCbCr" mean?
    Intel i7-950 ASUS GeForce GTX460 1GB 12GB G.Skill DDR3 1600 MHz OCZ Vertex 2 60GB SSD WD Caviar Black 1TB 7200 RPM 64MB Cache
  5. Member edDV's Avatar
    Mar 2004
    duh?
    All on the web sir. Heard of Google?
    10bit video = 64 to 960 (inside 0-1023)
    MPeg2 = http://en.wikipedia.org/wiki/MPEG-2
    YCbCr = http://en.wikipedia.org/wiki/YCbCr or http://www.poynton.com/ColorFAQ.html
    Sep 2006
    Could you please explain how 10 bit is more efficient for compression? I understand that more color information can lead to better quailty.
  7. Member edDV's Avatar
    Mar 2004
    Pro cams record 10 bit. Consumer cams don't.
    If you record 8 bit, 10 bit conversion is relatively lossy. That is unless you need a 10 bit timeline in which case only the 8 bit source suffers loss.
  8. Originally Posted by loster View Post
    http://x264.nl/x264/10bit_02-ateme-why_does_10bit_save_bandwidth.pdf
    Anyways, there's no way to edit 10-bit video in Premiere Pro CS5.
  9. Member edDV's Avatar
    Mar 2004
    I'm sure there is in YCbCr (since CS2) but I don't have CS5.
  10. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Originally Posted by johnnygalaga View Post
    Originally Posted by eddv View Post
    where did you source 10 bit x264?
    You can convert it to 10 bit mpeg2 ycbcr or better 10 bit cineform neo if you need to do serious editing.
    what does "10 bit" and "mpeg2" and "ycbcr" mean?
    (oops)
  11. Member edDV's Avatar
    Mar 2004
    I'm out of here
  12. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    No no, I'm gone. Sorry.
