Hey, i havent printed on DVD's for a whgile, but i need to again...
so i ordered Tayo Yuden DVD's white printable (J-DMR-WPP-SK8) . . . And now i want to use Nero Cover Design for the Printing,
but what i remember i need a file for the specific Printer? and or DVD Brand?
Couldnt ind Tayo Yuden or JVC listet.... Where can I get that file.... here i just found files for Photoshop...
THANKS A BUNCH !!!
Alex
	It's been a while since I've used Nero Cover Designer, but I don't remember ever needing a file for a specific DVD brand. Sometimes a special setting is necessary for specific printers, but I don't recall ever having to do that.
 Taiyo Yuden's Watershield discs are much nicer than what you bought and I'd recommend them for the future. They have a glossy finish that leads to some truly excellent results.
	well like i said havnt done it for a while...
 but dont i have to put in the specifics of the disc i use... so it prints in the right spot?
 or what other programm would you recommend?
	It's very similar to my Canon MP 640. Are you using the the US version, whose specifications on Canon's US site make no mention of a direct print to CD function, or the Canadian version which, if it's like my MP 640, has CD printing already enabled out of the box?
 If it's the former, you have to mod it to enable CD printing; if it's the latter, you can use Canon's CD Label Print software (if you don't have it I found it for you - or here), or in Nero Cover Designer, depending on how recent a version you have, a template might already be there in the drop-down list, or you can add one manually (painstaking), or you can add my custom paper stock templates in which there's one for the Canon MP 640, which should probably work in your MP 990.Last edited by p_l; 10th Oct 2011 at 11:57. Reason: added another source for downloading Canon CD-LabelPrint Ver. 1.4.2 (Windows 7/7 x64/Vista/Vista64/XP/2000/XP x64/Me/98)
  JVC Taiyo Yuden Blu-ray White Inkjet Printable 4X 25GB BD-R LTHBy xobituaryx in forum MediaReplies: 2Last Post: 17th Jan 2011, 10:25
  cover design softwareBy butterflies in forum Authoring (DVD)Replies: 17Last Post: 26th Jan 2010, 01:56
  On line Tayo Yuden dealer in Canada please ?By Zetti in forum MediaReplies: 5Last Post: 21st Aug 2009, 01:42
  tayo yuden cd-r watershield not verifyingBy mrtunes in forum MediaReplies: 5Last Post: 18th May 2009, 23:31
  Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R MediaBy mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
