Hi! I recorded a couple of SlowMo-Clips (using a Canon EOS 600D) - The clips are encoded as H.264 and have a framerate of 50 FPS.
Unfortunately, my video editing tool doesn't support proper editing of clips in 50 FPS - I can import them, but they get automatically "interpreted" as 25 or 30 FPS, depending on settings, even though the properties still show the framerate as 50. When I slow the clip down to by 50%, the program treats the source file as if it only had 25 fps, so only every 2nd frame will have a new content and half the frames are lost.
Now, I COULD render the individuals clips with half speed to 25 FPS-files in another program that doesn't have this issue and continue from there, but that would either mean quality loss or giant filesize and more re-encoding time for my ridiculously old computer.
I wonder: Is there a way to "patch" the clips in a way so the frames will get automatically stretched out to half speed and recognized as 25 fps clips WITHOUT re-encode?![]()
Cannot encode .mov file to dvd using ffmpeg
By RL in forum ffmpegX general discussionReplies: 3Last Post: 25th Oct 2011, 15:43 -
MOV File with AVC & ADPCM/IMA4
By JesseWV in forum AudioReplies: 7Last Post: 22nd Aug 2011, 14:38 -
How to encode audio to different fps?
By mrjust in forum Newbie / General discussionsReplies: 9Last Post: 16th Mar 2010, 22:07 -
How to encode videos with different fps?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2009, 15:14 -
Oppinions on encode please, 960x600 30 fps to xvid or ?
By Fenlock in forum Newbie / General discussionsReplies: 11Last Post: 18th Aug 2008, 17:22
