    Oct 2011
    lANCS
    Hi
    I recently converted a file from mov to wmv and although i set the video kbps to 1200 which it did the audio came out at 4000kbps when i looked at the file properties. I dont know if this is correct but it seems odd that the sound should be higher than the video as it was only set at 44hz.
    The problem that i have is i can get this to stream for some reason and the sound kbps could be the issue but im unsure as im not aware if there is a limit on the kbps on files that are for streaming
    Many thanks for looking sorry if the explanation is a bit odd but im new to this
    Software used was flip 4 mac
    although i have put it through premier pro and re encoded but the sound still comes out at a higher kbps
    thanks
    John h
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Post the results of Mediainfo here so we can look at video and audio properties.
    An uncompressed 16bit/48 KHz stereo pair is only 1536 Kbps.
    24 bit will increase that 50%
    96 KHz sampling will double uncompressed bit rate.
    http://www.kiva.org/about
