Hi,
I was trying to convert a couple of dvds to mkv files. I've already extracted a number of mpg files (each with one episode) using DVD Decrypter. As mpg doesn't handle chapter points, I decided to change the container to mkv. I found out this could be easily done using mkvmerge. However, I noticed looking at the output file that the original framerate was strangely doubled (25 to 50 fps). I'm wondering what could be the reason for this. The video itself seems perfectly fine. Also, if I specify a framerate of 25 in mkvmerge the resulting file is almost identical to the 50fps version, only being 400kb smaller.
Original (mpg):
mkvmerge output (mkv):Code:Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Duration : 28mn 48s Bit rate mode : Variable Bit rate : 5 033 Kbps Maximum bit rate : 7 500 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.485 Stream size : 1.01 GiB (91%)
Code:Video ID : 1 Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : No Format settings, Matrix : Custom Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Duration : 28mn 48s Bit rate mode : Variable Bit rate : 4 886 Kbps Maximum bit rate : 7 500 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate : 50.000 fps Original frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.236 Stream size : 1 007 MiB (91%)
Results 1 to 10 of 10
Probably because of Scan type : Interlaced. So its 50fps interlaced=25fps for the mkv container.
Just to be on the safe side, I would force MKV Merge to acknowledge the framerate of 25, Especially if you plan to convert to XviD or something.
Right, can you explain why? I'm happy to leave it at 50 or change it to 25 but it still feels a bit uncomfortable when I don't really know what the difference is. Or is it just, what Baldrick said, that 50 fps interlaced can be seen as either 50fps or 25fps?Just to be on the safe side, I would force MKV Merge to acknowledge the framerate of 25, Especially if you plan to convert to XviD or something.
When you play the file back, the timecodes will dictate the when each frame will be played, so most video players will still play the file at 25 FPS. BUT... some converters will get confused, and will try to double the frame rate, causing jerky video, as well as increased storage space.
IDK whether interlacing has anything to do with it. I could be that MKV Merge does not read vob files very well, or it could be interlacing. IDK. -
I see, thanks. I think I'll just leave it all at 50 fps and than convert it when I experience problems.
MKV 3D SideBySide with MKVMerge
By klode in forum Video ConversionReplies: 0Last Post: 12th Jun 2011, 08:54 -
making mkv using mkvmerge
By selv00201 in forum Video ConversionReplies: 8Last Post: 18th Apr 2011, 13:06 -
ts --> mkv, do I need tsMuxer+mkvMerge or vDub is enough
By adom in forum Video ConversionReplies: 17Last Post: 26th Jan 2011, 19:41 -
Problem joining 2 MKV into 1 with MKVMerge.
By LiBiDoXP in forum Video ConversionReplies: 4Last Post: 29th Dec 2010, 02:07 -
MKV corrupt? MKVmerge issue?
By TheParadox2 in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2009, 11:05
