This problem is related to playing mkv files on the computer. Particularly some more demanding 1080p types.
The one I generally use on my desktop is VLC, mostly because I'm used to it and because it seems to play everything. It's also very user friendly to deal with different subtitles, which I use a lot.
But things seems to be different on my laptop, and with many films the movement is "choppy" instead of being "smooth". It was suggested here that VLC was most demanding of the hardware, so I wonder if there's some setting up I can do to improve on that.
Another program that was suggested here was MPC-HC, and video playing is more smooth indeed. But on some cases, apparently some 1080p files too, audio gets out sync. So I wonder what is the cause for that sync-off and if there's anything I can do to correct it.
So as you see: two different symptoms for two different players. Anything I can do to tame them?
Results 1 to 17 of 17
Well, it's not so old really: dual-core cpu, 2Gb memory. Three years at most.
Things did not get that much better with Splash, unfortunately. Movement is smoother than with VLC, but still far from good. Frames seem not be being played, but tempo is fine, so it seems as the program is not reading all the frames, so it prolongs the ones they have. If you know what I mean.
Sync is better, but as image is not played as it should it's not something I can view.
OTOS it plays perfectly streaming on my LG player, with very good image and audio.
The problem is I need it to play fine on my laptop so I can sync the subtitles. -
Use mpc-hc in combination with LAV Filters and madvr (maybe reclock if it still out of sync).
Here's a good guide for setting one up : http://haruhichan.com/wpblog/?p=205 It's mainly 10 bit playback guide but will do well for your purpose. -
Whatever works. Don't forget, you have to stop and restart playing a video for the change to take effect.
The MPC-HC setup following the instructions didn't work. Once I changed the setup, when I started it back and played a file, there was not video and now it doesn't play any video at all, showing error after about 30 seconds. Now I don't know how to default back to the where it was at the beginning. Tried re-installing, but the preferences changes remain. There's no uninstall option.
No change. Just installed latest VLC version, which wasn't so much ahead as mine, as the setup I had was different from the one you described. But playback still still is awful.
But now the file plays fine in WMP and particularly in MPC (non-HC).
In fact I just noticed that some of the things I just changed seem to have made matters better in Subtitle Workshop too when playing this file. Probably they are related to WMP improvements, as I think SW uses it.
I just wished I knew what did I do that changed things. -
If you're comfortable using regedit, use it to delete the following key:
[HKEY_CURRENT_USER\Software\Gabest\Media Player Classic]
This will set MPC-HC back to defaults.
Another tip, when you're experiencing playback problems, open the task manager and see what the cpu usage is.
If it's approaching 100%, you may have found the problem. -
Now I'm back on my desktop, where I have a reasonably good graphics card (Geforce 9600GT), so part of my questions do not apply for now.
But still want a smooth play with all my players, so I can pick the one I want for specific things. My cpu is Core2 dual 2.13Mhz type. -
I have one notebook with atom z550 and gma500 - that is really poor configuration but I'm able to play 1080i50 smoothly wit mpc-hc.
I've tried:
haali, lav, av - splitters
ffdshow, coreAVC, lav, microsoft DVD-DVB - decoders
evr, evr custom, evr synch, madVR - renderers
I played A LOT with different configurations and different videos. After that I was able to find out what gives the best playback (read: smooth):
av splitter - as splitter (always)
coreAVC - as decoder - gma 500 has no CUDA but has DXVA and here coreAVC gave the best results
if for some reasons (unknown to me) coreAVC didn't want to switch to DXVA than I used microsoft DVD-DVDVB decoder
I was not able to run built in DXVA decoder nor ffdshow DXVA with the latest edition of MPC-HC - all I got was a blank screen - I reported this on their support page but till now no changes.
EVR (the basic one) - as renderer (I'm using win7) - forget about madVR
Try configuring mpc that way - set above as prefered (in external filters) and all the rest set to block (or do not install at all).
Maybe that will help
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 10:06 -
video doesn't play right in many players
By charlieship in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2011, 00:02 -
Video looks washed out in certain players
By pfxz in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2011, 18:06 -
Audio distortion (clipping) on computer drives/players but not dvd players
By Left/Right in forum AudioReplies: 2Last Post: 5th Nov 2008, 19:21 -
External Video Players
By tinz4 in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2007, 20:52
