Hi
I have an easycap device hooked up to try to get my videos onto dvd. I have honestech vhs to dvd installed, but it wont pick up the device, only my webcam.
I have found and installed the drivers for it, but nothing.
Im using it on a Toshiba L550 laptop.
Can anyone please help???
Kells
Ok. I have somehow got the program to pick up the easycap.
Now it only shows the video for 2 seconds then pauses. And wont keep going.
WTF am I doing wrong? -
You said it all. The drivers that you 'found' are possibly NOT the correct drivers - they really should have been given to you with the device.
You are not stating what OS you have and some devices do not like analogue capture beyond WinXp.
You do not state (not that it really matters) what version of this capture software you are using. But you may also like to check your settings(composite etc) and that you are not attempting to capture an incompatable format ie NTSC in PAL land or vice-versa. -
Also if you didn't buy it from here:
http://www.ezcap.tv/
...it's probably a cheap knock-off that isn't worth the postage you paid to have it shipped. Not that the original is fantastic....but the cheap knock-offs usually end up being unusable. -
Buying those counterfeits for $1 off eBaY is just not worth the trouble.
Yeah, you can't go wrong with $1 for many, but that only applies directly financially. The headaches you endure later, the time you waste, and the lower quality, is enough to say you can go wrong for $1, at least indirectly.
The original isn't that great either, but much more worth it for 20 pounds (or equivalent) than this cheap thing for $1.I hate VHS. I always did.
Easycap dc60+ problem
By jack123 in forum Capturing and VCRReplies: 5Last Post: 19th May 2011, 15:46 -
Problem with my Easycap 2.0 need help
By cher1269 in forum Newbie / General discussionsReplies: 0Last Post: 11th Jan 2011, 09:50 -
EasyCAP on STK1160 cropping problem
By amex in forum Capturing and VCRReplies: 0Last Post: 15th Oct 2010, 06:43 -
Easycap driver problem
By Jack_Dante in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2010, 16:22 -
Capturing PAL-60 with EasyCap problem!
By neoflame in forum Capturing and VCRReplies: 7Last Post: 18th Jan 2010, 06:56
