    May 2004
    Brazil
    I have a film where the ratio is wrong. So I would like to change it to make it right.
    This is what MediaInfo shows about it:
    General
    Unique ID                        : 190899867114641353639560184328187588891 (0x8F9DFA1FA8749E63A1939168B098B11B)
    Complete name                    : F:\file.mkv
    Format                           : Matroska
    Format version                   : Version 2
    File size                        : 6.55 GiB
    Duration                         : 2h 3mn
    Overall bit rate                 : 7 581 Kbps
    Encoded date                     : UTC 2010-09-17 07:47:46
    Writing application              : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul  3 2010 22:54:08
    Writing library                  : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format                           : AVC
    Format/Info                      : Advanced Video Codec
    Format profile                   : High@L4.1
    Format settings, CABAC           : Yes
    Format settings, ReFrames        : 4 frames
    Codec ID                         : V_MPEG4/ISO/AVC
    Duration                         : 2h 3mn
    Bit rate                         : 6 080 Kbps
    Width                            : 1 280 pixels
    Height                           : 544 pixels
    Display aspect ratio             : 2.35:1
    Frame rate                       : 25.000 fps
    Color space                      : YUV
    Chroma subsampling               : 4:2:0
    Bit depth                        : 8 bits
    Scan type                        : Progressive
    Bits/(Pixel*Frame)               : 0.349
    Stream size                      : 5.12 GiB (78%)
    Writing library                  : x264 core 104 r1713 c276662
    Encoding settings                : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=6080 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language                         : English
    Audio
    Format                           : DTS
    Format/Info                      : Digital Theater Systems
    Muxing mode                      : Header stripping
    Codec ID                         : A_DTS
    Duration                         : 2h 3mn
    Bit rate mode                    : Constant
    Bit rate                         : 1 510 Kbps
    Channel(s)                       : 6 channels
    Channel positions                : Front: L C R, Side: L R, LFE
    Sampling rate                    : 48.0 KHz
    Bit depth                        : 24 bits
    Compression mode                 : Lossy
    Stream size                      : 1.31 GiB (20%)
    Language                         : English
    The horizontal ratio is wrong, and I guess it might be a plain 1.85:1 or 1.77 instead.
    In fact, a test load in AvsP shows me that a simple change to 1.77 makes the image look "more right":
    Spline36Resize(720,480)
    But these numbers are wrong, because I would like to stay in HD quality. So the questions are these:
    1) What program, preferably avisynth related, do I use to make this HD conversion?
    2) What ratio should I use on Spline?
    Is there anything else I should or could do?
  2. Open in mmg, set the desired aspect ratio, save. But the video you're showing is 2.35:1, not 1.77 or 1.85.
    May 2004
    Brazil
    Yes, I know what MediaInfo describes is a 2.35:1 video, but the image is "wrong" for what is shown. Like when you take a 4:3 image and stretch it to 16:9 or more, if you know what I mean. People will be short and fat, right? That's what's happening in this video.
    May 2004
    Brazil
    Well, I did process the file through mmg.
    What I'm getting is strange: the file ratio seems to have improved when played on my laptop, using VLC or MPC-HC; but it doesn't change on my LG player. It plays exactly as the original file.
    What should I do?
  5. That means your LG player is ignoring the aspect ratio flags in the MKV header. You'll probably have to resize and reencode if you want the player to display it properly.
    May 2004
    Brazil
    OK. What do I use to do that?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Maybe uncropmkv.
    May 2004
    Brazil
    I made a short test with uncropmkv and it went fine. Now people look normal.
    The file is really a 1280 x 720 type with the 2.35 letterboxed inside it. I guess it was not cropped during capture or something like that.
    The total conversion takes about 4 hours, so I will do it overnight.
    Thanks!
