Results 1 to 9 of 9
  1. Every time I import a .mp4 video into Sony Vegas, it puts these ugly pixels throughout the clip.
    The video is perfect before being imported into my Sony Vegas Pro 9.0.
    Here is the .mp4 im trying to edit:
    http://www.megaupload.com/?d=FWZ0SMO2
    If i import it and place it in the timeline, i get these horrible pixel deformations (Highlighted below):
    and if i change the "Pixel Format" from 8-bit to 32-bit (full range), they disappear and it looks like this:
    but if i scroll down the timeline a little, it starts doing the same thing! (Highlighted below):
    If anyone can help me figure this out it would be SO VERY HELPFUL!
    My computer specs are:
    Intel Pentium 2.13GHz dual-core
    4GB DDR3 RAM
    and its an Acer laptop.
    If you would like to see this personally just add me on Skype and i can show you what im talking about.
    (Skype Name: HaffaWaffle)
  2. Does the final rendered video contain these errors?
    (I just watched it in Vegas Movie Studio Platinum 9 using default settings, and there are no errors - even when scrolling down the timelime).
    (using HP laptop/1.83 GHz Dual Core/2 GB RAM).
  3. Originally Posted by mike20021969 View Post
    When i render out the clip, it has all the messed up pixels in it,
    They ONLY appear when i import the .mp4 into Vegas.
    here is my render out of Vegas:
    http://www.megaupload.com/?d=QB7TDRKK
  4. I tested and rendered it out to Sony AVC and WMV aswell. No problems with it.
  5. so when you take the .mp4 annd import it into vegas, you dont get little pixels anywhere when you just scroll through the timeline?
  6. Originally Posted by HaffaWaffle View Post
    I didn't, no. I also rendered it out using Sony AVC 1280x720 - the end result was as clear as the original (albeit at a lower (for speed purposes) - 2.11 Mbps - bit rate than the original)
  7. The problem has to be within Sony Vegas itself, cause your having no issues rendering and everytime i render it, i get the same damned result!
  8. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Is your installation bogus?
  9. I just installed the newest version of Vegas and everything is fixed! it was just a bug in Vegas pro 9?
