Hi!! I'm thinking of getting a capture card, but from what I've read the picture blures a bit on some. Witch would be the best for my cartoon videos. Price range is around $150.
I have an AIW radeon and I am happy with it (now that i finally got the drivers to work with it). You can get them pretty cheap now that the new radeons are out.
Try an ATI All in Wonder Radeon, 32MB DDR. The price range is what you're looking for and you should be able to get great results with the card.
Here are some specs for the rest of my system.
1.1 ghz AMD Thunderbird (overclocked to 1.16)
1024 MB Crucial RAM
Abit KT7A Motherboard
2 - Maxtor 7,200 RPM 30 gig hard drives
After playing around with some drivers and finding the right software, I'm able to capture at 640X480, without dropping any frames, even during extended captures. -
I recently ordered a capture card from hauppage on Dell.com, and I received it, and is great! Definitely a great card. It has the normal connection for cable, but the great thing about this card is that it also has connections for RCA plugs (the white, red, and yellow plugs that are used by video game systems. This card was also only 100 dollars to. That is what I reccomend to you.
Wow Dude, Wow. -
I would also give a thumbs up to the Radeon AIW 32MB. I used to get dropped frames and had problems till I upgraded my box to an Athlon 1.2. Now I'm getting great Mpeg2 captures without losing any frames. I've been capturing some Invader Zim off of DirecTivo, and the colors are nice with good edges on stuff. Once I get the conversion to DVD nailed down, I'll be 'Dancin like a Monkey!'
FYI - unless your really heavy into games, there really isn't any reason to go higher up the ATI chain for capturing, since I believe the newer cards use all of the same capture chips/codecs.
HELP! Ripping DBZ dvds to my comp
By coops_1404 in forum DVD RippingReplies: 2Last Post: 30th Apr 2012, 06:05 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
