  1. Dear all,
    I am looking for a FREEWARE.
    Is there a simple tool that takes m2v & ac3 files as Input and outputs VIDEO_TS folder (VOB...etc files) ready to be burnt to a DVD?
    I know this is called AUTHORING, but I do NOT need any menus. Just the DVD should play the movie as soon as it is inserted into a DVD Player.
    I am looking for a tool that does batch processing. It has to take several m2v & ac3 file combinations and create Video_TS folders separately for each of those combinations.
    I do NOT need encoding functionality. Just plain, simple, menu-less, batch DVD authoring.
    Thanks.
    The only method I can think of would be to use command line tools, like mplex and dvdauthor in bat/bach file.
  3. Or muxman, if the files are 100% DVD compliant.
  4. Thanks to all. Having never used muxman, I opened it for the first time and it looked little complicated. I will need to research on how to get it to batch process the authoring. Is there a simple guide anywhere for this? Thanks.
  5. Check out BatchMux:
    http://forum.doom9.org/showthread.php?t=116297
    (you can download it from the muxman page here on videohelp)
  6. Thanks a lot. I'll look into that.
