not sure where to put this
having trouble with utorrent/torrents in general
need to download via torrent a copy of adobe reader as doing it via their website wont work
i had orbit which controlled downloads but i uninstalled it..but now all downloads say they are going to orbit when one doesnt exist on my computer
anyway after going to a page and trying a download i think it was rapidshare it came up with a pop up of mediadownloader which i didnt allow but somehow it installed on my computer./ i uninstalled it but now when i click to download torrents nothing happens
there used to pop up a window showing the file i click which of the files inside it want and it goes straight to utorrent now nothing !
i click download but it looks like its about to work but doesnt
sooooo frustrating
please help
Results 1 to 21 of 21
Your best bet it to find out why the Adobe download is not working:
http://get.adobe.com/reader/
It sounds as if, by messing with torrents and unofficial sources, you may already have been bitten by malware of some sort. The Adobe link above works perfectly for me. -
yes, what i am saying it when orbit was on my computer any download would go through that and come up in a window. i removed orbit but when i click on that adobe download link a page comes up saying this has been sent to orbit but i dont have orbit anymore
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Torrents are not downloads....and downloads are not torrents.
üTorrent cannot "download" that file from Adobe. You cannot "download" a torrent without a program like üTorrent.
That file you want from the Adobe site is one executable file. A torrent is many many pieces of a file scattered all over the world.
That "Rapidshare, Mediadownloader popup, installing without your knowledge" scenario you discussed in your first post suggests you may have already fallen victim to some sort of malware. -
From what I saw on a quick web search, your problem with Orbit isn't uncommon. The best advice I saw was to look at your browser plugins/addons for Orbit and disable/delete that. It seems the Orbit uninstaller doesn't do that.
I quit using Adobe Reader quite some time ago. It's bloatware, IMO. I use the freeware Foxit PDF reader instead and it works fine. http://www.foxitsoftware.com/Secure_PDF_Reader/ -
no you totally misunderstood me
i said i wanted to download adobe reader as a torrent, which i did, from a torrent site. i did this because when i tried to do it directly from adobe on their website, it would be assosciated with orbit and not download. a page would come up saying this has been sent to orbit but nothing would happen so i wouldnt be able to download it
i found the file on a torrent site and downloaded it throught utorrent
my problem with utorrent was once i deleted/uninstalled a pop up program that came onto my computer the pop for utorrent when i click download torrent wouldnt come up anymore
restarting the comp fixed that
however the orbit problem still exists i cant seem to get rid of it all on my computer so downloads arent assosciated with it at all -
If you cannot download it directly from Adobe here:
http://get.adobe.com/uk/reader/direct/
...then try downloading it from the FileHippo archive:
http://www.filehippo.com/download_adobe_reader/ -
I agree.
Adobe has turned into another Norton, Nero, even Apple (for PC), just bloatware that takes forever to install, load, etc. and is 80% useless.
Foxit actually defined itself as the reader to use if you don't want to use Adobeware, and it's working for them. And I too think theirs is so much nicer. And finally we have a Magifying glass for PDF that works as it's supposed to.I hate VHS. I always did. -
I'm not sure how Norton Antivirus which takes around a minute to install can be called bloatware.
I like it better than the free A/V products. It isn't what it used to be several years ago.If I'd known I was going to live this long, I'd have taken better care of myself. -
Norton may or may not be a quick installation, but the way it just takes over your computer, slows it down, gives useless warnings, does useless things (deleting shortcuts? c'mon...) and catches very little in the way of true malware comes close enough to what may be deemed "bloatware", regardless of the definition.
Norton was very good once, and a de facto standard for Anti-Virus protection. But in recent years it's very much like that fat cat, that sits around and does nothing, eats tons of expensive food all while the pesty mice, that should be getting caught, are running circles around it and having a party wrecking your home and its resources.I hate VHS. I always did. -
When was the last time you used Norton?
I don't see it using up much resources or causing a slowdown. It works for me. I agree some years ago it had gotten to be a hog. I suspect that they did a complete rewrite because it isn't what it was or I wouldn't have gone back to it.
If you do a new windows you can download a trial version and see for yourself.
Note that I'm talking Norton Antivirus with Antispyware not Norton 360 which seems to install really quick too. My only objection is I see so many of the 360 with a red x because they never configure the backup.
I just took a look at a Sony laptop with Pentium m 1.5Ghz & 512Mb memory. It is sitting here at 1% CPU usage and 548Mb PF and it runs fine with the 2012 Norton A/V w A/S. That's with all the Sony junk running too.
I just don't see the resource hog from Norton that people always cite.If I'd known I was going to live this long, I'd have taken better care of myself. -
I think the big complaints about Norton in the past were concerning the Norton Internet Security package that did seem to cause problems, at least on my systems. Not uncommon when one program seems to want to do 'everything'. I haven't used Norton for years, so I've no idea how it performs now.
I stay away from downloader helpers as I don't have a use for them. If you install any type of add on internet program you should do a little research first to see if it may have any negative affects on your system operation. -
Been a while, I will admit. (Maybe a few years.)
Well, even though I haven't tried it in a few years, the hog-reports on it continued after the fact, but I don't disagree that it is very possible that in recent times Symantec did get that message too and did that re-write. I wouldn't be surprised if that's the case lately, especially more-so now that I just checked and their website does say "faster".
Maybe I will. But I'm currently at an equilibrium with my system and don't want to mess with the ecosystem. But I will take your word for it next time I find I'm looking for an anti-crapware (or whatever they call it these days) package.
Just as much as I'm quick to criticize, I'm open-minded enough to give credit when changes are made.
You're likely using a different version than what people remember in recent times. Norton did turn off alot of folk so it would take a while before more people start reporting how good it might be lately.I hate VHS. I always did. -
I tend to lump adware, spyware, viruses etc into a Malware category. None of them are good for your system. They at least slow down internet browsing.
FWIW I also like how Norton has made it easier to have the latest version. Just click help and choose to check for the latest version. That's why my systems that were running Norton A/V 2011 are now running the 2012 version. People that just renew and don't also make sure to get the latest version may not be fully protected.
I see many infected computers here at work from customers and they all have one of several problems.
1. No Antivirus cause it slows down the system according to the customer. Not as much as a bad virus I say.
2. Expired Antivirus.
3. Client software for Torrents.
4. Pirated software. CrackZ sites are notorious for installing viruses IMO. with pirated software that was patched to bypass antipiracy measures, you don't know what else they added.
Summary: I would never go onto the internet without protection.If I'd known I was going to live this long, I'd have taken better care of myself.
UTorrent Theory
By Marco33 in forum ComputerReplies: 24Last Post: 5th Jan 2011, 19:12 -
utorrent scheduler
By chief-1 in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2010, 06:31 -
uTorrent inactivity?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 4th May 2009, 22:45 -
uTorrent Problem
By Nitro89 in forum ComputerReplies: 5Last Post: 14th Oct 2008, 07:25 -
Utorrent problems
By aslan in forum ComputerReplies: 6Last Post: 20th Sep 2008, 11:07
, but I don`t feel like checking that right now
